Guys with RollPans.....
SouthFlstrokin'
What are you guys running exhaust wise?
I'm trying to get ideas because I took my stack off and sold it. So my existing exhaust ends right at the back of the cab.
Thinking a cat back and running it back out the rear .
taking some 4" pipe with a turn down right before the axle.
Or ... Getting a 45* bend and having a 6" tip before the rear tire. Decisions.
Pics of your set up would be great.
powerstrokin15
Charleston, WV
have you seen rich's setup? he had a T from a stack and then two turndowns tucked up under barely showing. kinda hotrod looking. i loved it.
SouthFlstrokin'
I like his set up but that seems a little pricey. Trying to be a baller on a budget :D
I run no tip it dumps right at the hitch
You mean right after the axle? I'm worried about soot getting all over the rear when doing that though. Since I sit lower then you....
weazel
Elkview WV
I don't have a roll pan but my exhaust exits right before the rear tire 6" tip tucked just under the body looks good.
weazel
Elkview WV
Can you. get one of the whole system from the cab back also?
What is this "CAT" you speak of bwahahahaha, and excuse the filthy truck it has been snowing, Al Gore is full of $h!t
1badpsd
lebanon,tn
On a serious note do you have a reciver hitch on your truck? Ive almost bought a roll pan several times for the white dually but just dont know how itd look with a hitch. But until i decide its gettin xolor matched 08 bumper ive had in the garage for a year
weazel
Elkview WV
I had an old Chebby with a roll pan and a receiver hitch and it was set up to were the plate folded down to plug in the hitch, pretty slick
SouthFlstrokin'
You could go that route or move the hitch back 8 inches and run your stock one. I do not have a receiver on the truck at the moment, bit I'm gonna need one soon to start towing the horse trailer around once I fix it.
JMart
DFW
Im in the same boat as you. I'm about to pull my stacks and do something different but I want to do it cheap.
907DAVE
AK
I am going to dump in the stock location. Since the hitch will be much smaller and there is no spare, I will tuck the exhaust up tight to the bottom of the bed and turn it down so all you will see is the tip poking out.
