WILL IT FIT! again..
powerstrokin15
Charleston, WV
well. im thinking about ditching the 20x10's and getting some 20x12' in the same fuel throttle. my setup now is a 20x10 -24mm offset and 35x12.50 toyo MT. i was thinking of going to a 20x12 -44mm offset with a 1" spacer lift up front and trying to run my same 35's.. or if need be going to a 33".. im not wanting to level cause i like the tucked look and dont wanna spend the money on the block, etc to lift the rear to 350 height.. lemme know. i know most will be skeptical-but i was told my current setup wouldnt work either :poke:
Jhaddox
Negley, OH
LOL....do i have to say it?
You saw how my 33x12's ran...they barely rub at full lock, with a 35 without a spacer without a doubt you'll be rubbing
Are you sure you wanna do a 1 inch spacer?...20x12's stick out pretty wide as they are without adding another inch
IMO...sell the wheels AND tires...get a 305/55 and you're good to go without changin anything on the suspension
EDIT: saw you meant a 1 inch leveling spacer for the front..i thought you meant wheel spacer...hmm..that might work
powerstrokin15
Charleston, WV
LOL stfu.
i got a guy wanting to trade straight up for just wheels.. so i highly doubt me running the 12's on my height now.. 1" spacer block is like $100
MINK
London,OH
I was debating trying it on mine aswell.....but I'm gonna stick with a 33 as I hate rubbing tires.
here is 35.5" tires sitting around -60mm offset.......they rubed with my 2" lift
powerstrokin15
Charleston, WV
holy offset!! wasn't that with wheel spacers? i dont mind rubbing.. plus most of my fender well is cut for my setup.. i just dont wanna have to cut bumper or it to hit the fender. i was about to text you mink..
Jhaddox
Negley, OH
LOL stfu.
If it were me i'd trade and buy the spacer...try to fit them without the spacer and then if need be throw the spacer in
the logic im seeing is 20x12's with a 33 fit...35's are 1 inch on each half of the wheel, so jackin it up one inch would make the clearances just like a 305/55
Jhaddox
Negley, OH
if it comes down to the bumper being a problem why not just space the bumper out a little
powerstrokin15
Charleston, WV
yea i hear that. im thinking with a 1" block it working..
other issue-everyone around here was having a time getting my 12.50s off my 10" wide wheel. our shop machine couldnt do it gettting them on. could i do 12" and 12.50's?
Jhaddox
Negley, OH
My tire is only 12" wide...my tire guy hated me bringing him those
it'll work...just takes a little effort and a bead setter
MINK
London,OH
Yeah those pics were with spacers - hence the crazy offset.
I put money on them hitting the bumper...
12.50s go on a 12" wheel all day long....
Try it - I'd love to know forsure lol
powerstrokin15
Charleston, WV
well nick-monstar, is running a 22x11 with a 2.5" kit -44mm 35/12.50 and it ALMOST hits the bumper and the fender. he sent me pics friday.
Daryl@TDP
Chesapeake, VA
12.50s will go on a 12 wide with no problems. I've seen quite a few on 14 wides haha.
Daryl@TDP
Chesapeake, VA
I'm thinking it is gonna work with 1 inch. May be tight but it will suffice. It will look awesome with 12 wides though!
MINK
London,OH
well i need longer ubolts dont i?.. and we will see. first i gotta work out this trade
Think about that question.....there is no U bolt.
a longer center bolt comes with the bottom spacer kits - I am running the 2" version myself.
powerstrokin15
Charleston, WV
i meant center bolt.. sorry. ive never messed with coi style suspension.. ive always had leaf till this truck.
BlueWaffle
Grapevine, TX
unless you aint skeered to get after your bumper, front valence, and inner fender with a sawzall.....I wouldn't do it. fortunately...i don't mind hacking up my truck so been there done that with 20x12's and 35's. and that's WITH a 2.5" spacer up front.
