powerstrokin15
well. im thinking about ditching the 20x10's and getting some 20x12' in the same fuel throttle. my setup now is a 20x10 -24mm offset and 35x12.50 toyo MT. i was thinking of going to a 20x12 -44mm offset with a 1" spacer lift up front and trying to run my same 35's.. or if need be going to a 33".. im not wanting to level cause i like the tucked look and dont wanna spend the money on the block, etc to lift the rear to 350 height.. lemme know. i know most will be skeptical-but i was told my current setup wouldnt work either oke:
