cheap 5.4 coils....
oneturboforme
Think its just depends on what you want... I think blowby has 6000lb ones and I think his truck looks really good..
Jeff@Spartan
Georgia
He cut a coil off of his.
4800 lb springs with no rear block will sit dead level. I had 4400 lb springs with no rear block and my truck sat low in the front. 5200 lb will probably sit pretty level, maybe a little higher in the front.
OneStockQuik6.0
I got the 5c3z-5310-ga whats the rating on these? I haven't put them on yet but I will be taking off the rear block too..
OneStockQuik6.0
Those are 4400#
Are those good or should i go to the 4800#? Is that what your running on your truck, What i want is better 60ft at the track,softer ride,and leveled look...
Anyone have pictures of their truck with 4400# and no rear block?
powr2stroke
Tennessee
ya i'm running the 4400# coils , no rear block and removed the overload spring too . Not the fatty leaf but the arched one . Rides like a cadillac !
OneStockQuik6.0
You install those 5200's yet?
I'm looking at getting a set locally. My fear is the 4400 will be what I was looking for but that they'll start to sag and drop even more after time.
I don't have the 5200's...I have the 5C3Z-5310-GA, Which are supposed to be 4400..There are some members here currently running them and they haven't said anything about sagging..
powerlifter405
Butt Town
I found this @ tousley ford online and maybe it will help those who want a CODE and Spring Rate cross reference:
4,000--5C34-5310-AHB nothing found poss pre08??
4,400--5C34-5310-AGB Code W (4400 LB) 4WD
4,800--5C34-5310-AFB Code V (4800 LB) 4WD
5,200--5C34-5310-AEB Code T (5200 LB) 4WD
5,600--5C34-5310-ADB Code D (5600 LB) 4WD
6,000--5C34-5310-ACB Code C (6000 LB) 4WD
6,500--5C34-5310-ABB Code B (6500 LB) 4WD
7,000--5C34-5310-AAB Code A (7000 LB) 4WD
I posted this @ PSN maybe it can help some folks here.
powerlifter405
Butt Town
Rode awesome on my truck. I used the factory shocks. You'll want to trim the bump stops though. I never did and that would have probably made my ride even better.
Jeff, @ PSN you mentioned the 4800 VS the 4400.
Why that, I asked @ PSN but maybe share the thought here as well.
powerlifter405
Butt Town
If I can acquire both a 5200 and 4800, i'll grab both and test both out over the summer to see which feels better, control, ride, etc... I'll post my findings if I go that route.
