Irate's Full Fuel System Install
rusty1161
Whittier, CA
fully installed and loving it!!! its a little bit of a pain especially doin it the night before your go on a 380 mile trip be we got it! and deleted the EBPV all at the same time...... ill get pictures up tonight and this kit comes with everything.....!!
Any pics? I have his filter/pump bracket. It's a quality piece.
Thanks.
Rusty
powerSmokin
Marysville, Wa
When I did mine I didn't bother moving the turbo, I just chipped the back of the turbo housing where the snap ring is and then the fitting was able to be turned all the way. I know it's a little hillbillyish but it worked, I dunno about you but it made a hell of a difference, set it to 65psi and it gives you all with the little stock sticks.
Austin, Tx
So y'all are having issues getting the new fitting installed or the old fitting out? I remember when I did my fuel system, I had to cut the old fitting in half to get it out, but the new fitting I had fit just fine without touching the turbo.
brewer
Glad to hear you like it Zach, sounds like Jake makes some nice pieces. Those hard lines are sweet.
4.0l sahara
shelton,ct
Here are some pics of his system on my sd.
CSIPSD
Bend, OR
SOMEONE PLEASE MOUNT THAT REGULATOR...
Hummm lets hang a regulator from two hard pipes and see how long it takes for it to shake the fittings loose or crack the fuel lines...
4.0l sahara
shelton,ct
I have plans to mount it but it really is pretty sturdy.
CSIPSD
Bend, OR
Its solid because its being held by the fuel line. All the weight and shaking will cause the fuel lines to crack over time.
Just not a real smart design on that part.
Austin, Tx
I agree with Joe. Looking at the pics, I would definitely hard mount the regulator to an HPOP rez bolt or something... Not a good idea for the regulator to be just hanging out there with all the weight and vibration stress being put on the lines.
