Ceramic Coated Exh Manifolds
Derek@Vision Diesel
Canby, OR
Main reason would be to keep heat out of the engine bay a little bit, i dont think youd see any sort of gains other than that and they look good
Homesteader
Ok just wondering . The price on the coated manifolds went up quite a bit . I do plan on doing new manifolds though. I just thought it would help keep egt down.
Extended Power
Well...it should help keep the heat inside the manifolds...which will then travel up the up pipes hotter then before...and into the turbo hotter then before...more heat = more force to spin the turbine wheel = quicker boost.
kevin
springdale wa
Iv had a couple different exhaust manifolds coated... looks good for awhile but it dont seem to last
Homesteader
So what is this wrap that you guys are talikng about. Maybe I'll buy new stock manifolds and wrap them. The motor is on the stand so i think that would be a little easier? How long does it last? Will it peel later?
