My project from last weekend. Hpop, Turbo, Efuel!! pics
MossBack
UTAH
So January i bought a 01 Hpop from flea bay and a oring, gasket and plug kit from www.dieselorings.com
Then February a fuel pump from Jake @ irate.
And had a rebuild kit for my turbo so did that and a epbv delete.
my take on the tightwad mod. And Im at 80 psi fuel so i m sure that pellet in there is a bit much.
and filters from fleetfilter.com
But from the whole 10 miles ive drove it WOW. I have way more mid range and boost is rock soild and shifts at 25 might be time to consider going back to the 1.15 and see what i pick up top end. But its a beast on the bottom and mid!
And i did however first attempted the jb weld of the extras on the fpr and the epbv. Needless to say i lost some fuel and oil. LOL now i welded em.
And I grinded my welds and kept sanding holes in so i welded up and left it not as pretty as i wanted but its good for my scattered brain ocd i guess.
Pics.
spongebob915
Maryland
I had that air hose on my truck on the fuel system. Was told to remove not rated for fuel . Should use fuel hose.
MossBack
UTAH
That is diesel rated 3/8 synflex. At my work we plumb carrier refrigerator units with it. I can post the info from Eaton.com bit I have read that too.
If the manufacturer recommended using it I feel I'm OK. I'll post link from lap top in a few.
Sent from my PC36100 using Tapatalk
old man dave
Petaluma, CA
Pics.[/QUOTE]
If you're using a 1.0 housing, its probably less than 2 mph in the quarter, and the bottom and mid range say bye-bye. Been there and done that.
MossBack
UTAH
3270 Eclipse Airbrake Tubing
Construction: A multilayer product with a unique
flexible design.
Sizes: -06, -07, -08, -10
Product • Resists chemical attacks from
Features: diesel environments
• Exceptional abrasion resistance
• More flexible design
• Wide temperature range
-45° F to 250° F
• Thermoformable
old man dave
Petaluma, CA
.84 lol and top end levels off at 25psi so idk time for injectors..
An 0.84 is a low end only housing and a 1.0 would be a lot better for mid and top end and will hold its own against a 1.15 stock housing on the top end. The 1.0 is about 1/2 second faster 0-60 mph than the stocker and the 1.15 never makes up the difference on the top end. I use the 1.0 with stage II injectors with no problems, it will push 120 (3850 rpm governed speed/4.10s) anytime.
neverkickn
AR
A rating for "use in a diesel environment" and "rated for diesel transfer" are two different things. I would make sure it is rated for use as a fuel line before you get too comfy with it. JMO!
MossBack
UTAH
flexible design.
Product • Resists chemical attacks from diesel environments.
Features:
-45° F to 250° F
• Thermoformable
I am comfortable with it as I previously stated I work for a semi trailer manufacturing company. We send thousands of Carrier refrigerated units on the road every year that are plumbed with this very same tubing. Hence the reason I used it.
Thanks for your concern but I'm not to worried.:eek:
dave186
Idaho
I work on heavy trucks and trailers too and have seen plenty of units plumbed with that air brake tubing as well.
MossBack
UTAH
That looks cool to pricey for me.
The reason I ran the line I did is cause it was free and all the fittings.
I am invested a total of 200 ish for my efuel.
125.00 pump
72.00 fleet filter for bases and filters
50 in miscellaneous parts to orielly s
Old OutLaw
Suthren OryGun
yeah it's expensive, but I figgered it's still cheaper than going all AN fittings, and stainless braided lines.... and a hellova lot easier to run - plumb....
or fix in the field....
