97 CCLB F350 4x4 $7k OBO
Cat_rebel
Rebecca Black took my seat
After much thought I've decided to sell "Da Bus". Nothing wrong with it really, just time to move onto something new. A lot of you know what I've done to it but here is a current updated list.
97 F350 CCLB 4x4 4.10 gears 187k miles
The good-
- replaced seals/axle shaft U joints/ball joints in the front end
- replaced rear u joints & carrier bearing a couple weeks ago
- replaced tie rods/drag links
- replaced front calipers/pads/rotors & rear brake line
- replaced map sensor
- replaced IPR
- replaced steering column
- replaced glowplugs & relay with motorcrafts
- home made electric fuel system with 12mic pre pump/2mic post pump, stock SD lift pump, all 3/8" push lock
- home made reg return with a 4 way regulator to go to a 4 line feed if so desired
- stock trans shifts greats & has a triple disc converter
- stock Ford Alcoa rims are in good shape
- 4x4 works perfect
- gutted EBPV pedestal
- Herculined floor
- new powersteering pump
- new powersteering pump line
- new serp belt
- new alternator
- new superduty starter
- new fluids in both diffs
- new moog track bar bushings
Those are a few of the good things I can think of right now. The truck leaks no fluids running or parked. I daily drive it & get low-high teens for mpg depending on what kind of driving I do. I'm not scared to drive this truck 1000 miles tomorrow as it sits. It does need a few things for creature comforts but it depends on how fussy you are.
The truck will have stock injectors installed into it as well. The HD bumpers will be coming off & a good set stockers going on unless someone wants the HD ones that badly.
Sooooo the bad-
- no carpet in the int (I may throw one in there if I find one before it sells)
- deleted the A/C (have the parts for it)
- rear windows need motors
- front windshield has a crack on it
- front drivers side marker light needs to be replaced (turn signals still work & I have a spare just no time to install)
- tires need to be replaced before next winter
- only have front 19gal fuel tank currently
- driver's side of truck has body damage
- clear coat is pealing
- some rust but not like a typical northern truck
- hoodstack on currently (going to be looking around for a 3" downpipe & run a turbo back)
It's a good runner but I just don't have the budget or drive to do what I want to do with it. So figured it's time to sell it & move onto something new. $7000 OBO
PM me for further questions/details, thanks....
Countryboy07
N. Manchester, IN
I've got part of a 3" DP that I'd trade you for that hood stack... It is the part that connects to the turbo and goes down from there... I could throw in some cash as well... Let me know.
Bigsexy
Lochbuie, co
What all performance wise do you have done to it? Are hood stacks legal to run on the street where your at?
Cat_rebel
Home built fuel system, reg return, TS chip with MattR's tunes. Can't find a law against hoodstacks in MI & haven't been pulled over once in 2 years & I drive everywhere with it.
