Vacuum pump runs constantly
Spastik monkey
Tulsa, OK
I've recently noticed my vacuum pump runs constantly with the key on. The AC defaults to defront but will switch to whatever setting after a few seconds once the engine starts running. Any idea what would cause this?
BigAlsPSD
Pea Ridge, Arkansas
Vacuum leak, haha. Sorry just had to. Maybe a cracked reservoir? Or a split in a hose somewhere, check connections under the glovebox.
Mwilbur516
Check your hub seals. The seals get dried out, crack and leak causing the pump to run constantly.
MorganY
college station, tx
Fixed an issue like you described today. A/C at defrost and vacuum pump running constantly key on. This one happened to be the rubber connector at the vacuum pump. FUBAR'd
HOOV3R
Central PA
Went through the same thing with my truck. Swapped solenoids with my dads truck and it worked perfect. I think it was about $70 at the dealership.
Sent from my DROID RAZR using Tapatalk 2
Spindrift
Austin, TX
That damage looks exactly like what squirrels and mice do up in this neck of the woods during the winter months. Couple of years ago, I lost an entire engine when the buggers chewed through my engine harness.
Zmann
got mine from the ford dealer on this site 25% off and free ship
and to clarify a bad hub seal won' cause the pump to run and run unless the solenoid sticks open
Spastik monkey
Tulsa, OK
Replaced the solenoid. It still runs constantly, but after about 2 min the air will siwtch over to AC. I changed out the lines that go to the hub as well. I'm stumped
Mdub707
Mohawk NY
I'm in the same boat right now, just replaced all of the lines going down to the hubs. Both hubs have been replaced before under warranty, so they're not that old...
Where's this solenoid located?
Mdub707
Mohawk NY
Ok I'll have to check that out. Any way to test if it's bad or not?
My HVAC system will ONLY blow out the defroster now, no other settings at all. auto 4x4 still not working either... hopefully that solenoid fixes it.
spastik monkey, you have a spare solenoid you want to sell? Sounds like you just bought one and it didn't fix your issues, so your old one is probably still good right?
svilla
Have you checked the gray vacuum line that plugs in the valve inline with the heater hose on top of the passenger side of the engine? When mine had the same problem, that is what it was.
Mdub707
Mohawk NY
Checked it as far as what, making sure it's plugged in? I remember finding it unplugged a couple years ago when Ford took the cab off one of the times, and plugged it back in, still nothing. I even moved the valve last night by hand to make sure it wasn't "sticking" or anything. What exactly does that do there?
svilla
Yeah make sure it is plugged in. I would check both ends. Not really sure what it does. I think it control hot radiator water thru the heater core.
