Scanner Connection Issue
Marty
Elkton, MD
Scanner won't connect, truck is not starting.
2000 F450, harness was eaten up at several plugs and not making connection. 42 pin connector was stripped so I replaced engine harness from a 2000, replaced chassis harness from Late 99. Both were in working order prior to install.
It's not a bad pcm or IDM. Both were swapped with same issue.
It's not a bad ground, the truck started and ran prior to this just missed on cyl7. Everything is right (keys, modules, etc.) on scantool. Scan tool will work on truck right next to it.
No blown fuses. PCM is installed correctly.
No wts light, fuel pump does not kick on with key forward. It seems like a PCM issue but it's not. Truck is bone stock, no chip.
Thoughts?
bad12jr
Different pin out from the 99 chassis harness to the 2000 engines harness?
Sent from my DROID X2 chillin somewhere
BigAlsPSD
Pea Ridge, Arkansas
Does the OBDII port have power?
Marty
Elkton, MD
Top left ground doesn't work on a couple of trucks here.
Bottom left doesn't see ground with key off on either truck.
Layson
Just throwing this out there. Have you tried your AE on another truck recently? I had one of the pins in my AE plug push back into the plug. Sometimes it worked, othertimes it didn't... ??
Dave
OBD II port have power in the 450 Marty. Looks like you eliminated all other possibilities?
Marty
Elkton, MD
I'm using a snap on scanner. I connected to three other trucks today. Its not a scanner issue. its an issue in the wiring in this truck.
JLDickmon
it's either got a #30 fuse in the dash smoked, or the PCM grenaded when it was swapped..
Marty
Elkton, MD
All fuses are working.
PCM is fine, works in my truck and my PCM doesn't work in this one.
I guess I need to find a PCM pin-out. There must be wiring issue.
JLDickmon
it's in there somewhere..
  • Figure 18 Engine Performance Circuit 1 of 3.PDF
  • Figure 19 Engine Performance Circuit 2 of 3.PDF
  • Figure 20 Engine Performance Circuit 3 of 3.PDF
Marty
Elkton, MD
PCM wasn't getting a ground.
Removed and cleaned 2 grounds and everything works perfectly.
TARM
I was about to post you need to get the multimeter out and check ground at the PCM then I read your final post LOL.
On a different note speaking with the tech at AE ( i know you are not using this one) there module requires the power from the ODBII port. If you do not have power at that last pin out then AE will not work.
TARM
Hey Marty when is a good time to call you? I have some work I wanted to discuss with you.
Marty
Elkton, MD
Spoke to my Ford rep, not available yet.
Tarm, whenever. Good luck catching me at my desk though.
