torque specs for manual hub
obs7.3
Ohio
anyone know the torque specs for the wheel bearing nut and lock nut on a dana 60 with manual lockouts?
been looking around and can't get a consistent number for the inner or outer nut....
Parker, TX
Tighten the inner nut to 50 ft-lbs, then back off 90 degrees. Tighten the outer nut to 160-205 ft-lbs. Check the torque required to rotate the hub/rotor. Torque required to rotate the front disc brake hub and rotor is not to exceed 20 INCH-lb. Cheers!
obs7.3
Ohio
i didn't have the pads or caliper on when i did mine. you want the rotor set before you put the caliper on so the rotor gets seated properly
