piston to valve clearance
ChunderDownUnder
Man cave
Now , Is this right ?????
Heads nipped up (not torqued) on OEM gasket which measured around .087 thick
piston TDC on compression stroke, valves on # 1 cylinder held in place with test springs. Push down on rocker by hand and I get around .090 of travel before contact. Now if the OEM gasket has a quench .060 I take .027 of the .090 which gives me around .057 of piston to valve clearance.
Hotrodtractor
Mingo, Ohio
Factory specifications for valve recession into the heads are: 0.046-0.058" for Intake and 0.052-0.064" for Exhaust
Factory specifications for Piston protrusion are: 0.010-0.031"
If you use your 0.060" compressed gasket thickness of 0.060" - then you will have 0.075-0.108" piston to valve clearance for the intake and 0.081-0.114" piston to valve clearance for the exhaust.
All of this is of course if you are building to factory specifications.
Powerstroked162
On Da Juice
Wa. State
Factory specs blow ;)
ChunderDownUnder
Man cave
thanks guys. Heads have had new inserts and machined to spec although the deck to deck is a little undersize. Pistons have been decked for .025 protrusion. So all is good
ChunderDownUnder
Man cave
Intake .100 Exhaust .080
Now we move on
Magnum PD
VA
Wanted to get dimensions that Jason posted up. Machine shop is handling it, but I can't stay out the process. Need to check valve recess into head. .029 pistom protrusion, .010 taken off head and pistons. Kinda close I think.
