imelmo
- Joined
- May 18, 2011
- Messages
- 6,635
- Reaction score
- 2
Well, the bulk of the 4wd conversion is done and it looks AWESOME! :rockon: Jason at G Racing has done a fantastic job so far! :toast: Doesn't even look like the same truck and the short bed isn't even done yet.
But being as it's an '03 2wd being converted to an '05 4wd some parts didn't swap over and I need to track some stuff down.
I'm sure some of it I'll have to get from a salvage yard but I'd like to get as much of it as I can new if it isn't astronomically priced.
So here's some of the stuff I need. Any sources or recommendations for any of it would be appreciated. It all needs to be for a 2005 F250 4x4. Thanx!
front sway bar and bushings
brake lines (all)
track bar brackets and bolts
rubber isolators
shocks
pitman arms
caliper bracket bolts
u-joint strap, front shaft
trans/transfer case adapter
front coil springs (for a 5.4 gas motor)
And here's a before and after pic of the truck. He had to borrow some wheels because the 16" stockers wouldn't fit on the '05 axles.
brake lines (all)
rubber isolators
shocks
pitman arms
