zero rate/add a leaf?
blk350on20s
Hey guys. I need to center my axle. Is a zero rate block/add a leaf my only option? I need about 1.5" forward
Zmann
an add a leaf won't move you forward ? or at least I haven't seen that style ? if I missed an option please school Me
I have the same issue with some new to me springs I bought
they were sagged and shifted the axle back 1.5 " when they were installed .. I was bummed a spring swap is a PITA
I have two choices ..get them re arched or use a block that has multiple holes on the top For the springs center pin to locate into
bpb424
Chillicothe, OH
I had to use that block to recenter my axle
Zmann
PMF
It's a very well built kit. I used those style blocks and had him adapt his new traction bars for them. Below is a link w/ a few pics from it
Thx
I remember that thread .. I have talked to Him about the blocks without the trac bar mount ,, since I already have Fabtech bars and mounts ,, if I had to do it all over I would have went PMF all the way ,, and saved money LOL
blk350on20s
Ok now i didnt see that block yet. I like that better. The add a leaf kit installs by popping out your old center pin, put a bolt through one of the offset holes and through the center pin hole on your leaf and bolt together. Place the center pin in the center hole and bolt to add a leaf. Now your block is moved forward/backward
