where to mount the regulator
TARM
Mounted mine off the HPOP res stud It then allows the return to go right down the valley and out and the two front fuel line output from the heads to make a short curve up and into the reg.
GreenMachine
RI
Little bit of a thread jack but........ Will an ITP rr for a super duty fit a 95?
sweet guys! thanks.... how about blocking the stock regulator? i am keeping the riffraff stuff in place and running the lines from the heads to the aeromotive regulator then regulator to one of the ports on the riffraff fpr block, after i drill it out.
edit... just looked at the strictly link again and the idea i had looks exactly like that... didn't notice it the first time i looked at it...
the other guys may be able to answer that better but i thought i read somewhere that you may need to change the angle of the fittings coming out of the heads... but i am sure its the same other then that...
TARM
If its a bowl delete version I would expect you are correct. Best thing is to give Dennis a call he is very helpful.
mine prolly wont go there since for the time being im keeping the bowl. and will need to be able to change the filter...
TARM
I wish I had a Raff FPR in front of me or had messed with one so I could help you more. I do not even know what it looks like.
I posted the link to the riffraff RR in the fuel psi drop thread i made... i dont know how to do it on my phone or i would again.
neverkickn
AR
MossBack
UTAH
My 97
Sent from my PC36100 using Tapatalk 2
