38R Break-in procedure?
edge186
SLC, UT
I finally caved and ordered a 38R... Are there any specific do's or don'ts when breaking in a 38R? I've been told there is a specific break in procedure for ball bearing turbos..
On Garrett's website it says to let it warm up and test drive it then check for leaks. If everything seems normal then no further break-in is necessary...
I just don't want to take any chances...
blackbetty13
My breaking procedure on my 4202r was building boost to about 20 psi and letting her rip lol.
DEEZUZ
NO PUKESTERS
NWI
change the oil a few minutes prior to taking old one off. that way you got fresh oil going straight to the turbo... Also, pour some STP engine treatment into the oil port and spin the wheel around by hand
Dieselboy.
Surrey B.C.
This. Every turbo Ive installed i dump oil with a squirt bottle into the feed and rotate the wheel and allow it to come out of the drain.
That way your not firing it up dry hoping the motor oil gets to the bearings in time.
edge186
SLC, UT
I installed a bd turbo on a friends truck last weekend and I did pour some fresh oil in and spin it around prior to install. Which is the inlet and which is the outlet though? I wasn't sure so I put some in both...
pre lube, install, check for leaks, maybe a boost leak test(optional), turn truck on, let worm up a few min, put the skinny threw the floorboard.
David N
Eastern NC
After their procedure you listed it's all fair game. Haha
x2. 40lbs never felt so good! Mine went to the floor as soon as I got out of the driveway.
You'll be able to tell fairly quick if something isn't correct or if there is an oil leak.
edge186
SLC, UT
Well I got it installed and I can't find any leaks but I'm only seeing about 22 psi and that is topped out... Not sure why..
