Well bad news.
Groomzybanshee
St Joe mo
I believe I burnt a whole in a piston..... I will pull the motor and see Sunday... Guess it was Gonna happen sooner or later 3 years at 600hp on stock 230k bottom end..
KBMKVIII
Oh no! Sucks to hear. But I'm pretty sure as a pulling truck you may not have babied it lol
pontiacross
sorry to hear that. :poke:you should see if swamps has their new steel pistons pistons ready yet
Hotrodtractor
Mingo, Ohio
Never heard of burning a hole in a piston.
Happens all the time - can be caused by many things - but usually a crack that gives away just enough that it begins to get a hot spot, melt, and then when it gets thin enough - its like a blow torch cutting through the piston and sending piston bits into the crankcase. Its not seen as often in 7.3s as other motors, but it does happen. Its quite common in many of the common rail motors.
