4r100?
Illinois
Going to change trans fluid in a couple weeks and thinking about going with Shaeffers All Trans but havent heard anything good about using sythetics in this trans.
Sent from my C771 using Tapatalk 2
neverkickn
AR
Not to step on your toes Arisley but Brian Thompson advised me against it when I had a stock trans because the schaffers is so slick that the stock converter will slip more. He reccomended just the regular parts store atf.
neverkickn
AR
What if you have a heavy duty converter
Sent from my iPhone 4S using Tapatalk
Don't know as all I had was a stock converter at the time. I wonder if any additional slippage could be overcome with an increase in line pressure, but if that was a better way to go, then I suppose he would have suggested that instead....Mark is on, maybe he will chime in.
Fl Stroker
I was advised the same by Brian. Either use his special blend of Schaffer or regular Dex/Mercon 3. I believe that Blowby uses regular as well. Brian said the synthetic will cause the clutches to slip in a high hp application. So regular it is till next oil change for me. Guess I need to call Brian for some oil soon. Lol.
Illinois
My friend went to ford and for some reason they put mercron 5 in his then i called them and they said they dont make motorcraft mercron 3 anymore
From your mothers room Trebek
Mark Kovalsky
SE Florida, USA
I know this will sound like heresy, but if the fluid has a MERCON or MERCON V rating it is NOT slicker than non-synthetic. That's a myth and Brian is wrong if he is saying that.
An increase in line pressure won't help the converter overcome slip. The converter pressure is regulated to 120PSI, so no matter how high line pressure goes the converter won't see over 120PSI.
You can get synthetics that are no more slippery than conventional oils. They have a MERCON V rating. Mobil 1 synthetic ATF is one. If you are looking at #204S ALL-TRANS Supreme Auto Transmission Fluid http://www.schaefferoil.com/transmission-fluid.html it has a MERCON V and MERCON rating and will NOT be too slick for a stock transmission.
MERCON V is the right fluid. MERCON has been discontinued. There never was a MERCON 3 fluid.
When I got my fluid I got Merc v from the ford shop. That's what it said the 4r100 takes.
They are right. MERCON V is the right fluid.
jkidd_39
NW Arkansas
I was told the same by BTS. Actually had 10 gallons of sheaffers in the shop when I called. It may be OK to run it but I take Brian at his word.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
jkidd_39
NW Arkansas
Just goes to show he doesn't know everything.
I don't think this proves that you or Brian is right or wrong. Just differing opinions.
If anything he gave me advice that he believed would.make my Trans live longer. I'm at 340k on.a stock unit cept BTS valve body.
That is why he will get all my Trans work.
