Front Spring Codes
OBSWIZ
Wellington NV
SD's
X codes won't ride much stiffer than a V code and will ride better than any lift spring.
S — 2C34-5310-AAB, 4,000 lb.
T — 2C34-5310-ABB, 4,400 lb.
U — 2C34-5310-ACB, 4,800 lb.
V — 2C34-5310-ADB, 5,200 lb.
W — 2C34-5310-AEA, 5,600 lb.
X — 2C34-5310-AFA, 6,000 lb.
Bushwakd
Northern,Virginia
So do a set of U code springs up front, and how about rears ? P & Y with auxilary spring
Kevin my truck has stock V codes up front with 3" Icon Hangers. As Cary stated, his opinion is the U code does not have the strength for a CC PSD.
Skip the U code and go for a V code.
Homesteader
OBSWIZ I know we talked before but with and X code on a SD it will gain 3.5"? I can't remember what it was :doh:
03 tx pwr stroke
My truck says "V" codes up front. I guess that's why I seem to sit higher than onthers i've seen. Now how do I tell which springs are in the rear and do the different springs make the rear sit higher just like the fronts?
rat49f6
Vernon,NJ
Back code should be the next letter
A,b,c,
I've also seen e and n
Sent from my T-Mobile G2 using Tapatalk 2
Strokersace
Towanda, KS
Sub'd. Great info with part numbers, etc in here. At some point, hopefully soon, I'm gonna be in the market for 1 set of V codes and 2 sets of B codes.
jngreen
IN
SD's
What code is YC35-AMA ?
