Nitrous systems...
Mwilbur516
Ok, so what would be recommended for a guy who would like to spray every once in a while on a dyno and at the track in a truck with stock -155 injectors and a 64.7x88 VGT turbo. The truck holds 30psi at WOT and has water/meth. Or would I be better to just mix a slightly higher concentration of meth and no worry about the nitrous?
Powersmoker
Chesapeake, Va
ahhhh the beauty of a progressive controller......
1st Stage
2nd Stage
I have the Nitrous Express controller and love it, I use the "time based" for the drag strip and "boost based" on the dyno. Just mash the throttle and let the controller do all the work....no buttons to push.
2wd-fire
1st Stage
2nd Stage
how much is something like that?
jkidd_39
NW Arkansas
1st Stage
2nd Stage
Why use two stages that look like there characteristics are very similar?? Two different sized nozzles?
I am very new to nitrous so figured i would asked.
I checked my prices. Fir a nxd4000 progressive kit with a 10 or 15lb bottle was $750 even. That was from nitrous express
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
imelmo
mine is simple. one solenoid on a switch on the pedal and one on a button.
That's what I do. Nice and simple. I've been using TS's system. I just set the first jet as high as I can with still getting traction and the second jet to clean up the rest of the fuel.
2wd-fire
quick question what size line and selniod should i get? thanks in advance for like 100hp shot
Mwilbur516
Ok so the switch on the peddle.... I'm assuming the peddle has to be on the floor and then you hit the button to activate the second shot? I don't think the progressive controller would be worth it to me, but a simple button setup would be nice. I don't know about two stages though, I was thinking just a small shot on a button. I've got a lot to learn.
Cutting-Edge Diesel
Newkirk, OK
yeah On the ranger it has a micro switch for the first stage. On my Superduty im running a ZEX controller that you hook up to the TPS wire and program it to WOT. Its pretty easy.
Mwilbur516
So on your Superduty, it's a single stage system that will spray continuously as long as the system is armed and the peddle is on the floor? I have just always seen the button type controllers, like on the mustang in Gone in 60seconds. I would imagine you would only want spray while under WOT correct? Can you use NO2 under partial throttle or would it even be helpful?
Cutting-Edge Diesel
Newkirk, OK
yes that is correct. the WOT switch and the button are really the same thing. Only thing different is your foot pushes the button not your finger.
07_powerstroke
Upstate, NY
Well i have are local pulls coming up, and we can run nitrous. So i ordered a 0.84 nitrous jet a also ordered a a hand grip style push button and I'll use a toggle for a on/off swtich. I've never used nitrous before any suggestions about anything should I get a new tune? When do i hit the button and let off?
Pizza pig
In the Brig (Banned)
MD
make sure you've built enough boost is all I have to say :hammer:
