5.5" to 8" lift on a 05?
PTSUPERD
Saying hypothetically I was gonna go up a bit more...what parts would I need besides the obvious. 4.5" Icon coils would be swapped for 7" coils (+ existing TEI). I know I would need longer shocks. Rear would be blocks/bars.
Stock front driveshaft still good?
Just something I'm weighing cost of. Not sure I want to do it or not. I'd love to run 37s...
imelmo
Leave it alone. I need your junk outta there so he can get back on mine. LOL
Snake
Flo Rida
Gare -- front and rear driveshafts are good to go (no mods), as are the brake lines. If you don't already have a carrier bearing drop, I'd recommend one to eliminate potential drive line vibrations. I think you've got it covered other than the physical suspension components you already mentioned (coils, shocks, springs/blocks, radius arms / 4 link)
TonyG
Elkton,Md
Should do extended brake lines and that's borderline on safe with the front driveshaft..... If you were to jack the front of the truck up (not from the axle) like on a lift the front shaft will def pop apart..... Depending on bed cab configuration you mite need a rear driveshaft drop bracket for the carrier bearing
PTSUPERD
Right. I would reuse my PMF 3 link in the front. I have the ICON shim kit for the carrier bearing. Used all the shims...so might need to do more there..
Snake
Flo Rida
Tony -- I'm confused about the info you provided. I've been running an 8" lift on 37's for 5 years and my brake lines and drive shafts are just as they were when the truck left the factory. To my knowledge, Rize and Icon don't include extended brake lines in their 8" lift kits. In fact, no one I know with 8" of lift or less has lengthened their drive shafts or brake lines out of necessity.
JAP
In the Brig (Banned)
Diamondhead,MS
Seems to me like you'd need new radius arms, probably a bigger track bar drop, Pitman arm, and a front drive shaft spacer would probably be fine.
PTSUPERD
Already have the adjustable 3 link...so no radius arms...adjustable trackbar as well...
PTSUPERD
NOOOOOOOOOOOOOOOOOOOO!!
V. ICE is perfect the way it is man. I stress perfect lol
lol. Just was thinking more representation for the site. Lets be honest...its not going on the track.....
Figure it would look better in a magazine that way too... :lookaround:
Like I said. This is just something I'm looking at. Not a done deal...
Powerstroked162
On Da Juice
Wa. State
Just as long as its after my build lol
JAP
Diamondhead,MS
Just because your trac bar is adjustable doesnt mean your drag link and trac bar are going to be parrallel, all that serves to do is keep your axle centered.
Didn't know you had a 3 link.
Sprman
Houston, TEXAS
I don't think you would have to go that high to run 37's. "IF" you had an aftermarket bumper, it would make it easier. I'm at the same lift you 4.5" with a 1" TEI spacer and run 36's. I only rub on the front radius arm, but it's because my backspace on my rims is less than most of them out there and i'm running a 36x15.5 tire. IF i had more backspace, it wouldn't be a problem. And since you have the adj arm, you shouldn't have a problem either. I"m actually looking at running 37's as my next set as these are slowly wearing down to a point that i'll need to start looking. I'd like to find a set to put on to check one day. Just gotta find time to do it. Last time i tried to fit 37's, it hit the lower part on the front bumper. Now that i have the Iron Bull, it has more clearance.
