What do you think of this surface finish?
dohcter
Just as the title says. Is this block clean up goo enough. Or should more work be put into it. I still need to clean up the bores, water jackets, and bolt holes yet. Thanks psa. ImageUploadedByTapatalk1342118155.011807.jpg
Mdub707
Mohawk NY
How does it feel? If you drag your nail across it can you feel any gouges or anything?
DEEZUZ
NO PUKESTERS
NWI
What did you use? It appears you have removed the stains, which is not suppose to happen.
dohcter
I used the motorcraft gasket remover and a plastic scraper, then lapped the block with a 12" flatstone like mr Lott uses.
