Axle seal
8luggin
mechanicsville virginia
Anybody had Axle Seal issues? Looked under my truck today and both seals are pushed out.
Jlyl248
I asked a while back about them, apparently theres an updated seal kit
Zmann
that seal appears to be the updated seal ? i can't tell for sure
the old ones like everyone is commenting on sat on the the axle shaft this one insert into the axle tube see pic of My updated style
you can see the clean spot on the shaft where the old seal used to sit
GreenMachine
RI
that seal is the updated seal
the old ones like everyone is commenting on sat on the other side of the axle shaft
I don't think so, that looks exactly like the ones I did.
Other side of the shaft would be the knuckle seal?
Zmann
maybe I misstated ?
they sit in the same area as my picture just the old one mounts to the axle and spins with the axle
the new one sits in the tube and the axle spins inside it
His pic may be the older one I can't really make it out ,,
Zmann
shoot some grease into the unit bearing when you get it all ripped apart
blk350on20s
The updated one is metal that gets hammered into the housing. Has a rubber center that the axle spins on
strokedoutlaw
grand island Nebraska
got an 01 that has been like that since I bought it and not a problem, been through sand and mud and water and so on and so on, changed the fluid not too long ago still clean, like stated before nothing to worry just looks bad
