sunrisefordparts
Slave cylinder and master cylinder pre bled kit for 94.5 Powerstroke
Sent from my DROID RAZR using Tapatalk 2
master list $149.19 sell $111.89
slave list $145.70 sell $109.27
tube list $99.27 sell $74.45
switch list $85.98 sell $55.89
ford doesnt offer the pre bled kit for this yr.
q271869
Tom S
If they are available clamps for the rear driveshaft slip joint boot 96 F250 7.3 auto. Also a can of D2AZ-19590-A or it might be XG-8 in a tube teflon grease. It the slip joint boot only comes in a kit a price for that would be cool too.
Thanks for the spring bolts they were just what I needed and arrived quick.
sunrisefordparts
Auto 4wd electronic shift no floor controls
looks like 99-02 are obsolete through ford, but a 03 offers a dark grey carpert no black for single cab and dont think the floor panel is any different then your 99.
list $471.22 sell $353.41
q#271996
sunrisefordparts
looks like a boot kit list $29.70 sell $22.27
xg-8 list $7.92. sell $6.83
q#271991
blk350on20s
Both hydra boost lines. The one i really need is from the brake booster to the front of the motor. Lower drivers side radiotor hose(from lower motor to center of fan shroud unless it comes as 1 piece. Thanks
sunrisefordparts
pump to booster pressure hose list $55.08 sell $41.31
booster to gear box pressure hose list $32.71 sell $24.53
booster to resivour return line list $22.46 sell $16.84
i attatched a picture of the lines
q#272289
  • F-SD CHASSIS.pdf
sunrisefordparts
also the price for hose
list $111.00 sell $64.94 this is hose off front cover to second hose which runs to radiator.
q#272289
