OBS picture thread:
96stacked&smoken
pekin ,indiana
Actually it worked pretty good but need better tires it spun right from the start. I pulled 94 feet but it was an open class were i pulled against double overtime and other heavy hitters. I was doomed from the start but had a blast.lol
RubberDuck
Spicewood,TX
A 110v welder isnt good for anything more than light body work.
I disagree. I've built a lot of weight racks, part of my pulling truck chassis, the entire drawbar/ hitch setup, and countless drive shaft loop setups with a 110v Lincoln SP135. All of which have been tested repeatedly to see if the will contain, or stand up to what they should.
Now, that being said. Should you use a 110 welder for that? No. It doesn't penetrate enough. But with slow motions, and way more hours with a grinder to prepare than any one person should ever do....... It will get the job done.
97Beast
TX
Very nice! Do you have spacers in the back? It looks like the wheels in the rear arent as tucked in, it could be the picture maybe..
