dual hpops
Redneck6.0L
everyone knows the pros, more oil.
how about you ask how many trucks out there are succesfully running dual hpops and making power with them
Extended Power
Well, there was a COMPLETE Night and Day difference when I added the second HPOP to my engine.
Truck would fall on it's face whenever I got into the throttle too much...couldn't spin the tires at all...
Added second pump...blowin' the rear tires off with no problem now...:ford:
And I'm HAPPY!!!!!:D:D:p:p
Redneck6.0L
Do you have elite twin hpop's. I think there the only ones who offer a kit
Redneck6.0L
Is that it. One person here who has working dual hpops
Funny thing I do believe Ivan bought all his parts from a farmer store LOL
Redneck6.0L
Ivan and I are running a farmer dual hpop setup and neither of us default icp. I've been running my backwood redneck setup for two yrs. Trouble free
MorganY
college station, tx
Shawn a close friend has informed me on some info on you and Ivan's setups. It makes a whole lot of sense why some other kits aren't working as well...
Cutting-Edge Diesel
Newkirk, OK
Wouldn't your set up technically be called a helper pump and not a dual hpop? Sertainly not knocking it at all just trying to figure out how it is set up. How are your lines ran? If you don't mind me asking.
windrunner408
I don't really know squat about dual HPOP setups but it seems from what I have read and pictures I have seen it seems like there are two ways to do this. One is by having a separate HPOP feeding the oil rails from the opposite end (kind of like a dieselsite HPODS but with a second pump) and then the other way would be to use a second HPOP feeding the output of the primary HPOP (kind of building A LOT of pressure at the discharge). Does either setup (or both setups) require an extra IPR valve?? If so, how does one wire that in?? I would REALLY like to learn more about dual HPOPs. Hope I'm not TOO FAR out in left field. LOL
