cbuttre835
- Joined
- Jun 5, 2011
- Messages
- 172
- Reaction score
- 0
Ok so I have finally gathered parts for my bronco tank swap in my CCSB 97.
I dropped the spare tire and removed the two rear skid plate bolts. Very rusty, this truck is. Having to do a lot of sawzall work. Bottom of the tank is quite rusty on the outside. Hence my "water in fuel" and rusty fuel bowl woes...
I assume I need to remove the three screws holding the filler neck housing to the truck bed, to let that hose drop with the tank.
It got dark on me where I couldn't see well.
What about the wire and plumbing? What should I take loose before removing the two front bolts / nuts and letting the thing drop to the ground? Or is there enough slack in that assembly?
:doh::morons:
:doh::morons:
