Possible Turbo issue
01 blue 7.3
illinois
Sitting in a drive threw and the "jet noise" went away and doesn't the truck is a pooch now. Still has turbo but lacks power.
Sent from behind the hood of a long nose pete.
weazel
Elkview WV
Pull the intake and see how easy it spins
Translated from hillbilly, with tapatalk
Engineers clear the way!
bpb424
Chillicothe, OH
Sorry for the ignorance but what's VGT?
no prob man
it's a variable geometry turbo.
http://powerstrokearmy.com/forums/attachment.php?attachmentid=9907&stc=1&d=1348797108
I'm no expert, but your turbo has veins inside of it to change the size. It's smaller for quick spool up and then veins "open" to push more air. Something electrical could cause the veins to stick open or soot build up could cause them to stick open.
Have u ever noticed when you first start your truck it sounds like a big block v8 then a few seconds later it starts to whistle? that's the veins closing and causing that.
Just throwing out ideas trying to help.
01 blue 7.3
illinois
What if the veins are stuck? Easy fix or does that mean turbo is shot?
weazel
Elkview WV
Oh, I thought it was a 7.3, check the EBP sensor, if that is not the issue, then pull the turbo, and see if you can clean the vains, and such. If still no good, new turbo time. Happened to me
01 blue 7.3
illinois
Is that on the passenger side of turbo? Any way to check that other than buy a new one?
weazel
Elkview WV
There is a fitting on the drivers side manifold, follow the tube up should be right next to the upper radiator hose. It should throw a code, but I don't recall what code it is
weazel
Elkview WV
Fire it up, and check the oil supply line, it could be leaking from there, it need oil to actuate the vains
01 blue 7.3
illinois
Ok. What could cause the supply line to be messed up?
weazel
Elkview WV
No idea, just a thought, I like to check everything before I rip the truck apart
01 blue 7.3
illinois
Ok. In just trying to get some ideas of what might be the issue so i know where to start
