Smoking from takeoff
superdutyman97
McArthur, Ohio
I just bought this truck about a month ago, put a 4 inch downpipe back exhaust on it yesterday and now it's blowing grayish blue smoke at takeoff. Never smoked a bit before the exhaust. Could it just be burning crap out of the downpipe as I done away with the resonator with the exhaust install. Or should I be lookin for something more serious. It runs perfect and I just put 2 bottles of rev x through it about 1500 miles ago. It's only got 63k miles on it and is bone stock other than the exhaust. Any help would be great.
FX4 F2-Fifty
East Houston/San Marcos
Easy way to get it out. For the "tool" pictured I used a welding rod, to pry just put a 2x4 on the cowl and pry with a broomstick or metal rod etc.
Edit: forgot pic
Sent from my DROID BIONIC using Tapatalk 2
superdutyman97
McArthur, Ohio
Very helpful, I'm going to pull it out this weekend and clean it up and see why happens. Also going to check my injectors and see what I come up with.
CCRICE
Selah, WA/ Havre de Grace, MD
Other thing is how fresh is the oil? I know my buddies was smoking white, we cleaned his valve and he changed his oil and it quit doing it..
Chucky1313
Mines did the same thing I did the egr delete still smoked ended up being the seals in the turbo
Fromojo
After dealing with a friends 6.0L with a white smoke issue, you will have to answer the question of; Does the white smoke vaporize pretty quick or does it linger around?
Go away quick = Water, linger = Oil or fuel
I'm far from an expert, but we pulled the EGR Valve and it was as dry as anything besides the accumulation of soot for the past 9 years.
superdutyman97
McArthur, Ohio
It lingers around, I ruled out water vapor immediately. Ive been tinkering around and have traced it back to a sensor for the exhaust back pressure as of right now
Chucky1313
I had this happen to me did an egr delete did the headstuds and after all that it ended up being the turbo seals
