Adding Blocks
_DieselPower_
Michigan
I was thinking on putting my 99 7.3 on 35s. They should fit stock I might just need to move my front bumper forward with offset rims. My buddies were telling me it would look better if I put 2 or 4in blocks on her. She also sags a lil on the front so I was thinking on putting adda leafs on the front to level her out. Would I need bigger shocks for that? I still wanna keep her low and fast but wanna stand out a lil more.
Whats your guys opinion and you think 2 or 4in blocks would be better.
_DieselPower_
Michigan
As long as they will fit my 99! Yah Ill take em off your hands. Im up in Richmond. Im not sure where you are at
_DieselPower_
Michigan
DO NOT STACK BLOCKS. Remove the factory one and add a taller one if you want.
I planned on putting a lil bit bigger one on there not stacking em.
Does anyone know if I put Add a leafs in the front will I need blocks?
Mikes diesel-Ill give ya a shout truck should be back together by this weekend. Power Steering pump went on me
AKHILF
Eagle River Alaska
I did an add a leaf on my old 99 and didnt change the rear block and ran 35's. I liked it.
over 1,000 pounds on the bed there.
