Cool! The mount locations and driveshaft length the same?
fat-fingered from my EPIC 4G
Nope, 100% stock allison. Ill build it later down the road. No adapters for dodge trannys. Why would you want one a them Junkers anyway? And my dt360 will be 800+. But this thread is just to shed light on how to put an allison behind a 7.3 or 5.9 cummins or 6.0 Perkins or small detroits and cats. Since the dt360 uses mostly the exact same parts as the t444e (7.3) it's a good candidate to use as visuals for the 7.3 guys
Sorry, I read that wrong. Yes there is an adapter made by Carson stauffer to run a 4r behind the dt360. Check out pipewhiner's thread on psn. But I believe he's only around the 450hp mark iirc
Is that a built allison? I still can not see the point in this swap. You will still have to spend some good coin on the allison to get it to withstand more then 500hp. And if you are going to all the trouble to put in a dt360 why would you only want 500hp?
Not bashing on the build just trying to see the light at the end of this tunnel. Do they make an adpater to put the 4r/E4 behind the dt360?
If you guys are looking to put an Allison behind a 7.3 - I have a Destroked adapter and flex plate that have never been used and would make a deal on since my project died and gave up its parts for other projects to live.
