** 2000 FORD F-450 CREW CAB 7.3 POWERSTROKE DUALLY FOR SALE **
AirFishAutomotive
DELAWARE
since the craigslist add was flagged within a day i will post up specs here
2000 FORD F-450 FOR SALE
OFF THE START PLEASE REALIZE THE F450 IS MUCH MORE TRUCK THEN A F350, WHEN IT COMES TO HAULING, THERE IS NO COMPARASION. THE TRUCK DOES NOT RIDE LIKE A CADILLAC, THE TRUCK IS BUILT TO MAKE YOU $ AS IT HAS DONE FOR US. WE GET IN THE 14 MPG RANGE AVERAGE FOR PEOPLE INTERESTED IN THAT
DIFFERENCES IN THE F450 VS F350
19.5 WHEELS & TIRES (TOW BETTER, NO SQUATTING,MUCH MORE STABLE )
F450 HAS A S110 REAR AXLE RATED AT 11,000 LBS COMPARED TO A F-350 9,000 POUND REAR AXLE
6,000 POUND PAY LAOD
LARGER FRAME VS F350
LARGER LEAF SPRINGS VS F350
LARGER ROTORS
LARGER CALIPERS
LARGER BRAKE PADS.
26,000 LBS - GCWR
15,000 LBS - GVWR
17,000 LBS - TOWING
NOW ONTO THE TRUCK-
THE TRUCK, TRUCK ORIGNALLY STARTED LIFE AS A 2000 FORD F350 CAB & CHASSIS , WE ADDED THE DUALLY BED ON THE TRUCK . XL (ROLL UP WINDOWS, VINYL FLOOR)
TRUCK ITSELF HAS 305,XXX MILES ( DO NOT LET THE MILES FOOL YOU THIS TRUCK HAS BEEN REDONE TOP TO BOTTOM)
ENGINE HAS 161,XXX MILES ( REPLACED THE ENGINE WITH ANOTHER 2000 ENGINE (FORGED ROD ENGINE)
TRANSMISSION HAS 50,XXX (REBUILT TRANS)
MILES WILL CONTINUE TO GO UP AS THE TRUCK IS STILL IN SERVICE, THE ONLY REASON WE ARE SELLING THE TRUCK IS BECAUSE I WANT TO GET ANOTHER 2008-2010 F450 OR F550
-----TRUCK ITSELF-----
2000 FORD F450 CAB AND CHASSIS ( TRUCK IS 2WD = 2 WHEEL DRIVE IT IS NOTTTTTTT 4X4, WE USE IT FOR TOWING ON THE HIGHWAY WE DO NOT NEED 4X4)
2007 DUALLY BED
2010 TAILGATE (HAS THE EMBOSSED SUPERDUTY AT THE BOTTOM)
4.88 LSD REAR
TOW PACKAGE
TRAILER BRAKE CONTROLLER
THERE IS NO RUST ANYWHERE ON THE TRUCK AND THERE NEVER HAS BEEN !!!
----- GENERAL MATINANCE -----
NEW BRAKE PADS
NEW BRAKE LINES
GOOD RUBBER
NEW UPPER AND LOWER BALL JOINTS
NEWER FRONT SHOCKS
NEWER WHEEL BEARINGS
NEW HEATER CORE
----- EXTERIOR MODIFICATIONS -----
2007 FRONT GRILL
PTM GRILL INSERT
PROJECTOR HALO STYLE HEADLIGHTS ( ALSO HAVE STOCKERS IF THEY ARE NOT YOUR STYLE)
PACIFIC DUALLY WHEEL SIMULATORS
CLEAR LED CAB LIGHTS
CLEAR LED RECON FENDER LIGHTS
PTM LOWER BUMPER VALANCE
PTM MIRRORS
5% WINDOW TINT ON SIDE WINDOWS W/ 5% FRONT WINDOW STRIP
20% REAR WINDOW TINT
2010 REAR TAILGATE
----- ENGINE -----
160K MILE ENGINE JUST INSTALLED A FEW MONTHS AGO,WHILE ENGINE WAS OUT THE FOLLOWING WAS DONE
STAINLESS STEEL EXHAUST MANIFOLD HARDWARE
STAINLESS STEEL UP PIPE HARDWARE
NEW FUEL BOWL
NEW REMAN FORD INJECTORS
NEW UP PIPE GASKETS
NEW REAR MAIN SEAL
NEW OIL COOLER
NEW MANIFOLD GASKETS
NEW CPS SENSOR
NEW TURBO PEDESTOL O RINGS
NEW OIL PAN GASKET
NEW GLOW PLUGS
NEW GLOW PLUG RELAY
----- TRANSMISSION -----
COMPLETE REBUILD 50K MILES AGO
NEW FORD OEM TORQUE CONVERTER
BTS VALVE BODY
JUST SERVICED
----- PERFORMANCE MODIFICATIONS -----
SRP 1.1 HIGH PRESSURE OIL PUMP - CAN RUN ANY KIND OF INJECTOR YOU WANT UP TO A 300cc
6637 INTAKE
VAN TURBO ( BIGGER EXHAUST HOUSING - LOWERS EXHAUST GAS TEMPS AND MORE TOP END TOWING POWER)
WICKED WHEEL (INTAKE SIDE OF TURBO )-GETS RID OF ANY KIND OF SURGE
TS 6 POSITION CHIP ON CUSTOM SWAMPS TUNING
BTS TRANSMISSION VALVE BODY
GAUGES ( FUEL PRESSURE,BOOST,TRANS TEMP,EGT)
AIR INTAKE HEATER DELETE
CCV REROUTE
4 INCH STRAIGHT PIPE EXHAUST TURBO BACK INTO 7 INCH CHROME TIP
----- INTERIOR MODIFICATIONS -----
XLT CLOTH FRONT SEATS WITH FOLD DOWN CONSOLE ( TRUCK WILL SEAT 6)
PIONEER CD PLAYER
KENWOOD DOOR SPEAKERS
4 GAUGE POD WITH GAUGES
----- THE BAD -----
NO REAR BUMPER
DENT ON DRIVER SIDE BED (NOT HUGE AND YOU DONT REALLY NOTICE IS)
FUEL FILL LINE COULD BE RERUN BUT STILL WORKS PERFECTLY FINE
GAUGES COULD BE REMOUNTED
THE ADD IS VERY DETAILED SO ANY QUESTIONS YOU MAY HAVE PLEASE READ THE ADD FIRST TO MAKE SURE THEY ARE NOT ALREADY ANSWERED. THE PRICE ON THE TRUCK IS SLIGHTLY NEGOTIABLE. TRUCK CAN BE SOLD WITHOUT THE BED AS WELL THE ONLY REASON I AM SELLING IS THE TRUCK IS TO UPDATE TO ANOTHER NEWER 08-2010
THIS TRUCK IS READY TO WORK AND NEEDS NOTHING, IT WILL START UP IN THE COLDEST OF WEATHER NO ISSUES, NO TRADES, NO LOWBALLERS,NO BS PLEASE, WE ARE VERY BUSY, CLEAN TITLE , READY TO BE TURNED OVER
CALL OR TEXT
302-257-0228
AirFishAutomotive
DELAWARE
Vader's Fury
Chesapeake City, MD
Me and Marty had this exact same argument about this truck one day on the phone. I said it was a Dana 80 as well as that is what mine has in it and all 26 of the 450's that I have at work have in them as well.
This one does have a 110 in it. Idk why, but it does.
Hence the LOL
suprhlr
Zeeland MI
Hence the LOL
I've never seen it before either, so it has a square tube housing with a drop in 3rd member? didn't the 550 come with the D135
AirFishAutomotive
DELAWARE
Truck is still for sale. Can also be sold with out the bed.
Will get some interior pics this coming week.
Vader's Fury
Chesapeake City, MD
Yes it has the square tubes with a drop in 3rd member. I believe the 135 was only in the 05+ trucks but I may be wrong. My 2000 f-550 has the 110.
Price?
Marty
Elkton, MD
FWIW, the truck BJ (Vader's Fury) and I had a conversation about was an F550 (Tony's Flatbed). Square tube fo sho.
