mini pack or hanger???
nasty6.6
San Angelo, TX
Cant decide if I want to use a hanger setup or a mini spring pack to get 2.5 inches higher on the front of my 2000 f350. Any input would be good! Front sags 3 inches to the back and my 37s rub at full turn-
SPECS
4 inch procomp lift
16.5x12 alloys
37x12.5 goodyears
Suggestions?
yzrmbsg
Mountain Home, Id
Either works well, I've used both. Both are easy to install, both maintain ride quality. Just depends on price and preference.
02BigD
Coastal NC
The hanger lift that is on the truck now, rides exponentially better than the tuff country leveling pack that was on it 5 years ago.
No comparison.
nasty6.6
San Angelo, TX
ok i need 3 inches in the front to level would you go 4 inches higher or 2.5 which will still be a little lower????? so many choices.
yzrmbsg
Mountain Home, Id
Thats up to you, do you want the front higher than the rear? I personally like that look if its not too much. Mine is that way. 1in is fine.
