what starter is it again?
zilla68
Moore Oklahoma
isn't the deal to replace the obs starter with an 2001-3 starter? is it a direct bolt in? do i need anything else while at the store? I"m just buying it from advance online to save a little cash.
thanks
chris
OldschoolPSD
Central VA
There are three different starters. The one that is physically smaller is the gear reduction starter. Direct bolt on other than having to hog out the end of the cable for the larger stud.
zilla68
Moore Oklahoma
the one I posted says this:
Diameter: 89 mm
Direct Drive: No
Drive Tooth Quantity: 12
Gear Reduction Ratio: 4.2
Gear Reduction: Yes
Horsepower Rating: 4.8276 hp
Kw Rating: 3.6 kw
Mounting Bolt(s) Included: No
Mounting Shims Included: No
Nose Cone Type: Open
OE Manufacturer: Mitsubishi
Overall Length: 287 mm
Rotation: Clockwise
Solenoid Attached: Yes
Starter Finish: Same as OE
Starter Type: Mitsubishi Planetary Gear Reduction (GOLD)
Voltage: 12v
POWER-STRUCK
Indiana
6669 is a replacement gear reduction for 01-03 but i would recommend the nippondenso 17802 but engine crossmember modification is necessary on some trucks, its gear reduction and super fast with a large motor
zilla68
Moore Oklahoma
well right or wrong, this truck has NEVER ever started this easily. Hell I had to shut it off because I thought the 1st start was a fluke, since it started in like half a turn. fired it up about 5 more times and it fires super fast.
