x code springs
hunter scar
Hey guys i was thinking about putting a set of x codes on the front of my 2002. How much lift you get from them? Also do i need to get a adjustable track bar to go with them if so what brand? thanks Hunter
1ofakind79
Herminie PA
My f550 had x codes. It was 2" higher than my F350 dually up front. I don't remember what code front leafs are in my f350 off hand. But I do know that the x codes rode rougher than them.
jwlandry
S.W. Louisiana
2". And trac bar is reccomended but not NEEDED per say. Your axle will be toward the driver side a inch or so more
OBSWIZ
Wellington NV
A track bar is requires unless as stated you like the axle offset, bushing wear etc...
X codes will ride stiffer but great for a snow plow or heavy winch bumper.
2" hanger kit or a mini spring pack will ride better with the factory v codes..
longer shocks should be used except with a mini spring pack
Pm me if I can help, we carry all.
cary
hunter scar
Thanks for the info guys im gonna probably get a set of x codes and put them on hopefully in the next two months i will post pictures. What is the best brand of adjustable track bar to go with?
hunter scar
cary
I would go with that route but one of the stock springs is gone and replaced with two add a leafs on one side. So im just gonna put a new set of springs on the front.
02POWERSTROKE7.3
Alexandria, IN
I think it rides fine. I can measure it tomorrow. I used a 4" block in the rear to level it. 33" tire on a 20x10 just barley rubs at full lock.
OBSWIZ
Wellington NV
best..icons Billet bar.
We also carry a DOM bar that must be painted but its cheaper..
Pm me if I can help.
I run the icon billet and highly recommend it. You buy it once and your done for the life of the truck. plus it looks cool!
OBSWIZ
Wellington NV
X codes and a 2" mini spring pack is a 4" lift...at that point I'd do a drop track bar bracket and a droped pitman.
