Guys with Max Powers... what air filter you running
78f100
Bonifay FL
Just wondering what kind of intake everyone is using? battery relocated?
If anyone has pics that would be great!
78f100
Bonifay FL
I think no limit has a kit out now, pm mike if he doesn't chime in.
Edit: found it!
http://powerstrokearmy.com/forums/showthread.php?t=23958
That looks good wonder how it works with the max powers?
As for now, I believe that elite's big chill filter is the only intake setup that precision approves of.
I really don't want to relocate the battery but will if I have too.
I think Shane is having good luck with his home built intake, But I'm not sure what filter he has on it.
i believe tadd/elite has approved mine using the pro5R , it handles my high powers no problem with 110's and 65psi. i refused to relocate my battery for the elite intake, just didnt wanna make changes that drastic under my hood.
White_monster
The great white north
I've got the same filter as the no limit and its keeping up with max powers and 110's just fine. The no limit intake would work great. The Elite intake uses a massive filter which is nice but it requires battery relocation. Both options work great but the no limit kit is much simpler.
Wayne
Twin Falls, Idaho
As far as warranty goes, it really comes down to condition of the thrust bearings when a warranty is claimed. If your lack of intake flow caused the thrust bearings to die, you don't get the repair covered under warranty. For this reason, Max Power compounds include the new "big chill" intake. My intake is similar to the No Limit design, and with a "semi-dirty" filter on tow-powers, it pulled my non-updated filter minder in half-way. this exact same intake worked great on Erik's high power compounds and 110's with a clean filter. A clean filter goes a long way. We obviously can't force anyone to use the filter we include, especially if somebody bought one of our kits used, and it didn't come with a proper filter kit. It really comes down to cause of damage if somebody claims a warranty.
78f100
Bonifay FL
Pretty sure I'm gonna give the No Limit intake a try. I really don't want to relocate the battery. I always keep my filters clean so hopefully it will work out good. If not I will try the Big Chill. I know these turbos were just rebuilt at Elite, do they have a warranty, or is that only to the original purchaser?
it will.
