Anyone running these?
ghohouston
Lewisville,Texas
Ehhh what exactly would there be other than performance? Im not asking a smartass question either, but really, what else could happen from banjo's?
Big Calo
I wonder if there is anyone that sells a fitting that just threads directly into the head? Seems like that would be the best option to reduce turbulence, and increase flow.
CSIPSD
Bend, OR
Not really looking for the performance aspect as much as air to the injectors or maintainning fuel pressure...
I might get them just to try anyway. Not a large cost so...
Magnum PD
VA
Would rather get DI's 6an adapter in the head. Plumb the fuel line right into the fuel rail.
dentexpowerstroke
denton, tx
You can just drill them out and it'll be the same as those bolts. Riff raff has the stock bolts so you can have a back up set if you want to go back to stock.
m j
BC Canada Eh!
sorry for the dumb question but, who is "DI"?
I want the -06 adapter for the fuel rail
googling it but 'DI' is a pretty vague term :)
ty
Michael
JDub
Hooper, Utah
I ran Strictly's banjos in conjunction with his regulated return on my big motor build. That truck made 900+ without fuel pressure dropping. I could've drilled out the stockers, but was worried about them breaking. These weren't that much in the scheme of things...
m j
BC Canada Eh!
I found this pic on another powerstroke forum.
that old thread also stated DI as the source. emailed him.
just reposting the image for other that are looking.
