dual hpop
MorganY
college station, tx
Out of all the options out there at this time, running a second pump has far more potential, that's why I decided to go that route. Also, it will allow you to go up in a few more sizes on a conventional style injector body before you have to switch to hybrids.
g2shuck
I saw and thought the same thing Chris. Do you think an OEM cac tube would work for the 04.5+ trucks?? I agree too. The setup does look nice. I like the simplicity.
Jesse's kit includes a new cac tube to fit around thw twin pump
Jwarren
Ill be posting pic of complete kit and info up soon. New a couple days till we get the final version of the pulley done, some CNC parts. Pump is also modified to run ball bearings.
06FX4
Miami Fl
To run yourndual pump what needs to be modded? I'm running your 225s on stock oil 06 and can't get more then 2 volts on xterm ex. Have everything in oil system new 5-40 rosella and revx.
Wayne
Twin Falls, Idaho
We do up to 225's with the '03-'04 pump. The newer one is great, but usually produces a little less than the older style.
