Builds DONE!
Jhaddox
Negley, OH
With Craig and everyone else beating the stock rods and them holding up the way they are made me do it
SEABEE08FX4
Montgomery TX
Just read threw it all as well.
Mind telling us what exactly changed your mind on the rods?
Can't wait to see you run this thing at Rudy's in March and I'm sure you'll probably piss yourself once you finally get to drive it again lol. Awesome build!
Sent from my DROID4 using Tapatalk 2
6.0/6.4 rods are pretty stout.
bft blue oval boys
Burlington, NC
Yea, I knew that just was more wondering about what they were talking about with the aftermarket rods being "unfinished"or something?
And I don't blame you for saving that 3+ grand when the stockers are holding up fine lol
Jhaddox
Negley, OH
What post number? I honestly forget
Jhaddox
Negley, OH
Ok found it...they needed a little extra when they came in when Shane got his set...that, as far as I know isn't the case anymore
I didn't go with em solely because of a cost perspective
White_monster
The great white north
Not to derail the thread but the Carrillo rods still don't come finished. Takes about 5mins a rod to finish them. Just needs a quick file to take the sharp edge off the split point. Do this so when the bearing is rolled in that there is no material scraped off the back of the bearing that could pile up under the bearing and cause a high spot. This should also be done to the block where the bed plate meets the block. Just a stroke or 2 of the file is all that's needed, no major work. Hope that clarifies the unfinished part.
Derail over.
Jhaddox
Negley, OH
Well I finally have an intake coming, thanks to Shane (white_monster) for coming through and helping me out on that...he heard the problems I was having and got one made for me in 1 hour...I really appreciate it buddy!
I just have to order a filter and I should be good to go
I don't have a hold up on getting my truck drivable again finally
Sent from my SCH-I535
Erikclaw
Central CA
You own a Ford?? Great to see it coming together, been a while. Now lets see what a lots of fuel will get cha. :ford:
Jhaddox
Negley, OH
Any updates, really hoping the manual PCM gets rid of the wrench light with the 4R conversion. Thanks
-Stew
Just waiting on a day it's not snowing so we can get the engine to the same place as the truck...hopefully it'll be running within 3 weeks then the tweaking with the wrench light will happen
fine69
Cranberry Twp,PA
I have an enclosed trailer if you need it.
