head removal question ASAP
89 Stroker
Southern Cali
finally got i think everything undone on my 97 7.3 pass side head
got all the bolts that hold the head on, removed exhaust manfold / removed that fuel whatever line that leads to the back of the head, the thing wont budge, anything im missing?
ghohouston
Lewisville,Texas
double check you got em all out, otherwise, there will be a good seal on them, you will have to kind of "jerk" up on them, or at least in my case. hell, i pulled heads on a mack haul truck today, and each head (macks are split 3 cyl. per head on some of them) we had a cherry picker, and it didnt even pull them up, we still had to jack with them to get them off the block
89 Stroker
Southern Cali
iv got a hoist n such, im iv double checked and i think i got em all, when i try to pull it the whole motor just lifts up, gotta be the seal but ill triple check
89 Stroker
Southern Cali
well guys, finally figured out the problem, about a month and a half ago when i was changing fuel lines in the fuel lines on the fuel bowl, i knocked a small hose clamp into the intake plenum, but i soon found another small hose clamp at the bottom of the valley(thinking that was the one i knocked off) ran fine for the month untill i gunned it and it ended up getting CRUNCHED into the piston, now i dont know if its any good, any ideas?
kyle43335
In the Brig (Banned)
You should be able to save the hose clamp!!! Lol
kyle43335
i still need it!! haha what do you think the options are for this?
The pictures are fuzzy. But it looks like your going to need a piston and possibly a head.
I have heads to sell if you need them?? In reality if the head isn't. Gouged to bad or cracked? I would smooth out the sharp edges and reuse the head. Piston replacement is a must.
89 Stroker
Southern Cali
last pic shows the puncture the hose clamp made on the head, look bad enough for a new one ?
