Always do sh!t yourself.
Eastern Shore Of Maryland
It was finally time to change my fuel filters since the last time they were changed was when I bought it around 15k ago. Shop quoted they changed them. But to my surprise the bottom one never was. ImageUploadedByTapatalk1363900056.465558.jpgImageUploadedByTapatalk1363900077.710280.jpg
SEABEE08FX4
Montgomery TX
Those look pretty bad, but for reference the drain on the FMFP will always have trash come out of it. Thats the stuff from outside the filter that did not pass through and gunk that may have collected in the drain nipple. But those are pretty dirty for on 15k.
Well that's good to know I think. Makes ya wonder how much was in the filter. And I'm pretty sure the bottom one was skipped last time.
Atsah
Maine
You have a picture of the updated one?
The updated filter pak is Motorcraft part # 4616 and the one above is a # 4606.. The 4616 has an added o-ring to keep water from getting through to the injectors..
Atsah
Maine
That's wat I put in there. Good deal. And I wish it was an oil filter
Do you have the updated fuel pressure regulator kit installed on your truck? When I installed the 4616's the first time, I lost a little fuel pressure.. I updated the FPR kit and fuel was happy again..
DEEZUZ
NO PUKESTERS
NWI
you can get the cheaper kit without the housing also, just spring, bolts, gaskets, and valve
