22x12s
MINK
London,OH
What's the offset on the wheel? I know that a 35x12.50 on a 10" wheel just fits but with the larger offset of the 12" wheel and the fact that the tire is alittle wider I think you will need 2.5-4" lift to make it clear Jarret.
ClayStewart
Weatherford, TX
I have 22x10's on the same tire with a 2" level. Had to trim the fender well, some sheet metal and cut part of the fog light housings to make it completely rub free. I don't see 12s working on stock suspension.
TrickTruck
Simpsonville, SC
12" wide w/ 4.5 backspacing equals a negative offset -38. Everybody is running positive offsets these days. My wheels for example are a +10, stock is like +30 or +38 or something like that.
I'm running the same size tire you are looking at. At full lock I just barely clear the fenders (and I did a little work with the hammer too.)
With that width and backspacing you'll be sticking way out and will likely rub the fenders at full lock. I think what you are looking at will not work well on a modern truck that's designed for positive offset.
Also, 12" is too wide for those tires. They are probably rated like mine for 9-11".
IMHO you should be looking for a 22x10 with an offset of +10 to +20.
jwlandry
S.W. Louisiana
Tires are rated for a 12 wide. They fit perfect actually. I was thinking about putting the weld wheels off my 03 on the 12.
Bigcountry250
They will rub for sure, I'm running 20x10 wheels with 305/55-20 tires and I had to trim a lot to get them to clear
Powerstroke586
Eden, Utah
I was told stock is more like +12 to +15
I think most people are doin negative offsets these days not positive
under construction
Jamestown, OH
I have 22x12's with the same size tires and a 2" leveling kit and I still had to do a little trimming so I don't think there is anyway that they will fit on a stock height truck.
