6.0 no start, spring found in filter housing
FallenAuthority
La Plata, MD
That really looks like the spring from the drainback valve at the bottom of the housing. The black plastic plunger sits on top of the spring. How did you verify that the drainback valve works? Are you not getting base oil pressure?
Atsah
Maine
Sure does..
kyle43335
In the Brig (Banned)
That spring looks way to big to be for the drain valve.
Op said he found it in the oil bowl. It has to be the oil stem spring. Op. Was the spring just laying In the bowl after you took the oil filter out? Or was it up in the filter?
FallenAuthority
La Plata, MD
Compared to what? There is nothing to reference to in the picture? That spring looks just like the drainback valve spring. Also note the OP said SMALL spring. The stem spring is NOT small by any means
OP can you take a pic of it next to a quarter for reference?
kyle43335
There's 2 springs in the oil stem.
speedracer1000
everett, pa
im betting its from the stem, almost has to be, plus if i remember in middle of the top of the stem there should be a little black piece of plastic holdin this in. its missing as well
speedracer1000
everett, pa
the top of the stem is spring loaded but didnt u say there was 2 springs? this is the smaller one im sure. wut issues would this cause?
