E-Fuel Parts list, questions
jmsmith76
Middle GA
Well my stock system sprung another leak so I think I'm ready to scrap it and build an e-fuel system. I'd like to keep the whole thing between 500-600 bucks. I want a quality system, not some rigged up crap, but I don't want to spend a ton of money either. Here is the parts list I have so far:
Regulator - Aeromotive 13109 - ~$150 on Amazon
Pump - Airtex E2236 - ~$100 on Amazon
Pump mounting clamps - something from the hardware store
Fuel/Water Separator Ass'y - Stanadyne 33640 - ~$70 on dieselstore.com
Final filter - Wix 24770 base & CAT 1R-0750 - ~$26 on Amazon & ~$18 on eBay
7/8" Freeze plug - $1 at the parts store
Liquid filled gauge - ~$20 from Driven Diesel
Oil pressure switch - ~$14 from Driven Diesel
Wiring/relay/etc - TBD, looking for some input on this
Fittings - TBD, looking for input on this as well
Total so far - ~$400
I'm looking for some input on where I could cut back on cost as well as a few additional parts I'm not sure which route I want to go yet.
Does anybody know where I could source a stock SD pump bracket? I'm leaning towards not getting a junk yard pump because I'd like to put all new parts on it, but it's not out of the question.
For the routing on top of the motor, I'm thinking I will use either a 2 way block, or get one of THESE y-blocks from summit. Then I will cut the banjo fitting off the stock lines and reuse the stock lines, run fuel injection hose between the feed line, y-block, and stock lines. Unless someone has a good way to reuse the factory banjo fitting.
As for wiring, do yall think it is worth it to buy the $120 harness from Driven Diesel with the pump controller? Or I could make my own harness and I'm thinking run a wire to the GPR to have the pump run when the glow plugs are running, as well as using the oil pressure switch from Driven Diesel. If I make my own wiring harness, what is the relay that most people use? I don't think I'm going to fool with running the wiring into the factory fuse box, at least not for now.
Is the Stanadyne FM100 series fuel/water separator worth the cost, or should I buy a different setup for pre-pump filtration?
I don't like the idea of having my junk hanging down below the truck with no protection, so I want to fab up some kind of skid plate that bolts on for easy removal at servicing time.
Open to thoughts, comments, criticisms, etc.
Thanks
old man dave
Petaluma, CA
Wix sells their version of the Stanadyne Fuel Manager series filters/bases also. Amazon has a variety listed as Wix Fuel Manager as filter/base packages for about $50 in the FM-100 size. You do have to google the filter number since there is no description of filtration size. The Wix FM series are interchangeable with the Stanadyne FM-100. The Wix does have a slightly lower pressure rating than the Stanadyne bases though. The fuel/water separator functions are in the filters themselves, not the bases.
Instead of using a y-fuel block that takes AN-hose, use one that has standard NPT sized holes, use pushlock diesel rated hose and fittings, its cheaper than using AN braided stuff and probably just as good for the average guy. (unless you're going racing where they may require the braided line for safety reasons).
There are fuel pump brackets available, but the stock factory brackets probably are just as good from the auto wreckers. The SD fuel pumps are probably the most reliable ones out there, there are higher capacity ones out there though like the Bosch -044 (around $230) and very reliable also.
Electrically, just pick up a wire hot on start and run positions of the ignition switch. This will start the pump on startup. You can just use a fuse box tap ,tap a fuse in the fuse box and feed a 30A rated auto relay wired in series with the oil pressure switch/inertia switch that will control the fuel pump. Use 18 wire to the relay fused with a 5A fuse. The relay is just the black 1" cube with a mounting tab sold by auto parts stores everywhere and even RadioShack. Run a separate fused power wire throught the relay for pump power off of the battery. Use a 20A fuse if you use #12 wire or a 30A fuse if you use #10 sized wire.
The Stanadyne FM series stuff is a serious industrial quality filter system, Bean's used them in their original electric fuel system. Bean's employed C-channel stock that just fit inside of the frame rail and mounted the two filters and fuel pump on it, a very compact means of mounting them and tucks the parts up out of the way. The Stanadyne FM series filters also come in three different lengths so clearance can also be adusted by your selection of filter lengths. The longest filter element reaches about 2" lower than the frame. Never had a problem with my Bean's setup.
stay away from the airtex... can get a stock bosch sd pump from riffraff for 145$. walbro gsl392 is a good option too if you have a good pre pump filter setup. if i did it again i would parallel two bosch stock sd pumps. a complete fuel bowl delete system will be close to a grand when its all said and done for a decent one. even diy.
jmsmith76
Middle GA
Great info guys. Thanks! I just ordered the Wix Fuel Manager 24912 off Amazon. From research, it appears to be the same pre-pump filter that the Bean's kit uses. It's 30-micron rated and uses the 33912 filter element just in case anyone else needs that info.
What makes you say stay away from airtex? I haven't heard anything bad about them until now. Not arguing, just curious.
why? why not buy a new one from riffraff and not worry about it being trashed or weak or gummed up from sitting? spend a little more money now so that you don't have to again and again... trust me, most of us on this site have tried to do a budget or cheaper rout and it always seems to bite everyone in the azz...
jmsmith76
Middle GA
Are you suggesting using the factory mounting solution or just buying the pump and making a mount for it? Looks like riffraff sells the pump only. I don't have a problem spending a few extra bucks, but the factory assemblies new are $300+. If I can find a cheap factory mount and get a new pump, I'd like to do that ideally.
not to hard to make a mount... just need to add some rubber gromets to help with vibration. but if a junk yard has the mount then do that.. or a couple bucks on some large hose clamps, a small plate to mount it on and some rubber gromets between the plate and whatever you bolt it to...
run 3/8 line from your tank selector to a pre filter then to the pump then to a post filter then high pressure 3/8 line from pump to the motor, if you want to delete the fuel bowl then run a yblock to feed the heads and the regulator will get the return lines... can pull all the stock fuel lines and connections out of the truck and replace with either 1/8 npt to hose barb or find a hydraulic hose shop and use hydraulic hose and ends to make it nice and neat.. i think they will be 1/8npt to 6jic fittings can do it like this if you want to keep the bowl or run a y block instead. http://dieselinnovations.com/techfiles/reg-kit.pdf
jmsmith76
Middle GA
I guess I'll go the bosch route then. As for the top of the motor, I'm not sure if I want to make up some new lines or try to reuse the factory lines.
What do yall think about this banjo block
jmsmith76
Middle GA
Planning to ditch the bowl, just thinking about using one of those banjo blocks so I don't have to fool with bending lines or pulling the turbo. The turbo pull isn't bad, only took 35-40 minutes last time, just would prefer to not have to fool with it. If I do stick with factory lines, I'll upgrade the lines later when I pull my turbo to install a d66 in a few months or whenever I get around to buying one.
superduty4x4
Newport, WA
Cut the lines off at the factory banjo fitting and attach your new fuel lines to them, that way you still don't have to bend lines but you get rid of the stupid leaking POS banjo fitting.
jmsmith76
Middle GA
Very well may do that. Or maybe I'll quit being lazy and just pull the turbo and make up some new lines. Who knows
Old OutLaw
Suthren OryGun
I'm running this Carter fuel pump, and it's been on there a year, and trouble free.... :
http://powerstrokearmy.com/forums/data:image/png;base64,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****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***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
  • fts3.pdf
jmsmith76
Middle GA
Yeah I saw that Carter when I was researching and marked it down for reference. I think it was around the same price as the OE unit from riffraff when I looked it up
Old OutLaw
Suthren OryGun
one other thing....do NOT put too fine a filter in FRONT of the pump (inbetween the pump and tank), as when that filter starts to plug up, it will make the pump pull too hard, and burn it up...I used a 32 micron filter, (Wix33367 water separator-filter),
http://www.fleetfilter.com/mm5/merc...fleetfilter&Product_Code=33367&Category_Code=
and it's working just fine....I AM running a 2 micron in between the pump and injectors (Wix 33528).... both on Wix 24770 bases.
jmsmith76
Middle GA
From what I read 25-35 is ideal. I ordered the wix fuel manager with a 30 micron element for the pre-pump filter and the same wix you have for post-pump.
not a 100% sure but i think the bf1212 baldwin is 40mic. its what the majority of the sponsors use for the pre pump filter. but like i said not 100% on that.
