cheap 5.4 coils....
stroken
I keep finding this part number, what exactly is it? 5C3Z-5310-EA
I've been looking for the 5C3Z-5310-AGB 4400# springs, cant find them!
BOSS450
Concord, NC
My reg cab sits dead level with 4400# springs and no rear block
BOSS450
Concord, NC
I towed a generator to my house the other day for a party. That's the extent of it.
on edit the truck behind it is my tow truck.
stroken
I didn't remove any rear springs. My current setup is no rear block and 4800 lb coils. It sits level. That setup you quote sits pretty nose down.
Can you get me a few more pictures of this setup? I want to go a little lower then the 4800 but If I cant take enough out of the rear to get it to sit level id rather go with the 4800 if I absolutley have too. How much higher was the back? inch or more?
blink6.4
Pittsburgh
Anyone run 4800s and no rear block with a 20x12 -44 offset and 305/50/20 (ill be running 420s) I want to order everything in the next few days just want to make sure it's gonna fit first
stroken
That's what spring and tire I'm running now with a 20x9 Bmf. But ordered a 4400 spring and 20x14 last night
blink6.4
Pittsburgh
And you have no worries as far as rubbing cause if your going an inch wider wheel and lower than me I guess that means I shouldn't have any issues
stroken
I'm going to a 3 inch wider wheel. 9-12. And with that much offset I see no worried in it
