lowered trucks with riderite bags
StockCar#10
cheyenne,wyoming
Looking to know if any of you guys lowered your trucks that are running any suspension bags, also bags with a b&w turn over hitch.
Would like your input on them and to see pictures if you got them
RiVerBum01
lebanon, tn
I called the guys at ride rite an they said there systems wouldn't work with lowered trucks. I don't see the difference in a truck being lowered 2in or a truck with a heavy load on the bags making the back sag 2in, so idk why it wouldn't work.
BOSS450
Concord, NC
It depends on how you lower the truck. If you take the rear block out it does not change how the ride rite bags are installed.
StockCar#10
cheyenne,wyoming
Ok which kit would you say?
ALso throwing this in the mix...truck also has a b&w turnover hitch
PowerstrokeJunkie
Maryland
The only difference the b&w hitch plates make are that you may need to use longer bolts on the top bracket that you drill through the frame to attach.
