Cruise control?
cthomas7192
Houston tx
I just installed my exhaust egr delete and spartan a few days ago and cruise control worked fine then tonight it's gone. What might cause this and how to fix it?
Thanks
PSD-BLACK-CLOUD
TX
Mine did that. I learns that if you had the cruise set you had to turn it off before you went over 95. Or else this would happen. So next time you go to pass a car hit the off button then get on it.
03silvertj
It just so happens I just had this same problem. I too have the Spartan tuner. Turned out it was the anti-lock break switch assembly. The switch went bad and was basically telling the cruise control that I had my foot on the break. I had the dealer replace mine, I've heard of others replacing it on their own.
I've had no problems with my cruise since and I've switched tunes a couple times since then.
