PatriotHauling
Well this was fun
to the rotela haters. Why is it we have 7.3L engines with the original injectors at 400 thousand plus miles, since there first oil change they have had nothing but 15-40 rotela.??? that does not spell junk. We run our T6 for 10,000 plus miles between oil changes and never have a problem. not even with a idle.
the best oil to date i have run in my pickup was Cenex brand oil! Will be switching to Conklins next.
I actually found my 6.0L and 6.4L's to run better on Rotella T6, as compared to Mobil 1 5W-40. Not sure why everybody is hating on Rotella, they have came a long way since the old days.
The old days being when? I used that oil from 02 until 05 in my own truck and for a couple years more in a company truck with horrible results. I havent poured Rotella in probably three years. They made inroads in the last three years? I highly doubt it since Bean had a trouble thread up last fall that wound up being resolved by draining the dino Rotella.
If you like Rotella, thats your right, but there is plenty of proof from "the old days" up until a few months ago of Rotella suckin balls in our trucks. Having been there myself its not bs.
Are youguys running stock trucks that think its great lube oil?
Dont know why anyone is knocking any oil. I use motorcraft 1540. My truck has had that for ten years as a ford dealer parts truck. Now I own it, lift it and beat the piss out of it.
It may be...if ford uses a certain additive in their oil, and rotella obviously has different whether full syn or not, they may react/cancel out the benefits. Run the same oil if possible. That's what I have done and will always do.
Edit: not one of my trucks has ever had less than 220k on it. And god only knows some of their previous owners and what they did to those things...
First of all, you said t6...
Second sentence you said Rotella...
Rotella refers to 15-40 shell rotella t oil.
Ive been following along in this thread and you've been talking about Rotella T also. Ummm, unless you have proof, rotella T wasnt synthetic oil even 2 years ago. So if you arent sure, better check. I would but.I dont.care to. Every oil thread for the last five-six years someone.comes in banging the t6 drum only to whine and tremble when its laid out for them that its made wih dino base oils. As it probably still is. So if you care and have a point in life to prove this, by all means, go ahead. I dont.care enough to.
I didnt use rotella personally that whole time. My truck, used the oil until I actually eliminated every possibility that it could be. Switched oil and the problem went away too. Ive poured a lot of that garbage into other peoples trucks and equipment over the years. Thats what I meant.
Not all Dino oils suck,btw. Delo 400 is better than most synthetic oils.
Ill have to take you at your word that t6 is good. You'll have to take mine when I say Ive.been around a long time and ten years of horrible performance out of an oil brand isnt something that is.easy for.people to.forget. T6 was not good oil two years ago even so maybe your frame of reference is very small?
@sickstroke-you just said your 6.4 runs.better on t6 than.whatever else. How is a cr truck running differently on t6 than mobil1? Oil has jack to do with idle quality or anything else you would be able to notice. Im pretty sure the dealership puts rotella(dino since you get confused) in my 12 dmax. Yea, those.trucks dont give a rats ass what you lube them with.
Oil quality doesn't affect the idle? LOL
First you say T6 isn't Rotella. Now you say oil quality doesn't affect idle or any aspects of engine performance. What's next, we didn't actually land on the moon? LOL
