sunrisefordparts
Could I get a price on a core support for a 96 f250 with bushings, and the bolts. And a shipping quote to 49341.
core support list 782.85 sell 587.14. bushings bolts nuts washers and shims to mount sell 268.94
quote 245154
call 909-822-8736 to order or for complete breakdown
free shipping
need a price on the flange yokes on the rear driveshaft, need the 4 bolt flange thats at the end of the u-joint on both the front and rear of the shaft, transfercase, and rear diff
08 F-350 cclb
8ea60441
sunrisefordparts
08 F-350 cclb
8ea60441
F list 76.98 sell 57.73
r list 65.95 sell 49.46
quote # 245284
free shipping
SouthFlstrokin'
Need a quote for a engine oil temp sensor(on the back of the hpop reservoir). And a iat pigtale for my e99. Thanks.
David N
Eastern NC
Can you get me a price on the International Up-pipes to replace the stock uppipes on my 2002 7.3. International P/N 1837872C93
JD3020
Farmersville/Dayton, Oh
Can i get a quote for both valve cover gaskets and all 4 under valve cover harness's for a 97 7.3? Basically everything to replace all the wiring and connectors on both heads. Shipped to 45325.
swamp_ratt
hudson, wi
Ive revised what i need for my order. Heres the parts #s!
389838s100
387165s2
N801201s2
385127s2
D4tz-10001s7-c
Should be the 4 cab mount bolts and the top side washers for each corner as well as the retainers for the rear cab mounts. If numbers are wrong i appologize
sunrisefordparts
389838s100 obsolete but available. at 28.00 ea list 38.00
387165s2 list 11.00 sell 7.50 ea
N801201s2 list 3.35 sell 2.09 ea
385127s2 list 9.82 sell 7.50 ea also obsolete but available
D4tz-10001s7-c list 42.90 sell 29.25 ea
quote # 245778
quote # 245778
sunrisefordparts
gskts list 78.68 sell 59.01 ea
wire assy list 61.32 sell 45.99 ea
free shipping
quote # 245783
sunrisefordparts
ford part # are pipes only f81z.6k854.ea list 42.38 sell 31.78 f81z.6k854.fa list 52.30 sell 39.22
quote # 245782
CAT35niner
NJ
Is it possible to put in a power slider in a truck that has a manual slider. If so wat would i need and prices Thanks. The truck is a 2008 Ford F250 6.4 6spd ext cab short bed
