Using AC = MPG halved???
O2ShootTheJ
Okay I've had this issue for a while now, and maybe its just the nature of the beast, but I'm hoping I have something wrong. When I turn my AC on no exaggeration I use about twice the fuel as I usually do on trips. Is everyone elses truck like this or do I have something wrong?
Getting tired of driving with the windows down in 100+ weather
Dtm030
FL
Could the air unit be seizing up and put way more pressure on the belt?
That could be dumb but I had to ask. The unit on my 2008 was making squeeling noises on start up all the time, sounded like it may have been going out but never did.
yeah half doesnt seam right, and even then 1 mpg is probably a stretch to be honest.
Driving the supercharger, which i know takes more HP then an a/c compressor mileage didnt change much if any, so i dunno, sounds like you may have a bigger issue but who knows.
TurboM700
Minnesota
Not saying this is the case here but the mid 2000 year Ford tauras had the same issue and it end up being whent he AC was one it would change the 5v ref to the MAF sensor causing it to think it had more air going thru it and this would cause a rich condition along many other things. Its been a while since I have worked on a 6.4 so I cant say if they even have MAF sensors. I know the 6.0l do and thats mostly what I work on.
It was an easy check with the vehicle running and up to temp. Read the MAF value on the scan tool and see if it changes with the AC on or off. Do this both idleing and going down the road.
Mike
O2ShootTheJ
I haven't done a legit MPG calculation w/ AC on and off but I'll go ahead and try to do that. I guess I'll fill up, turn the ac on, drive somewhere, and fill up again for the AC test.
I've just noticed that a drive of about 30-35 miles or so will usually end up using about 1/8th a tank there and back with the ac off and closer to 1/4 tank there and back with the ac on.
Mike
Thanks Mike I will definitely check this out.
O2ShootTheJ
yea i checked it on the way home. maxes out while im driving but at idle it didnt vary at all between ac being on/off.
I'll see if i can get some solid mpg numbers over the weekend
BFT
southern cali
i see a big time loss with city driving with the A/C on. i normally leave the A/C off until i hit a long stretch of highway and a consistant speed
BFT
southern cali
you probably wont notice the small loss if you do small commutes. to people that drive far and tack on 3-5k in less then a week it makes a difference. noticing how many you mailes you get to a tank, lets say the op gets about 400-450 miles to a tank and now gets about 300-350 is big
